Pega Marketing Program Run sequence number
As the marketing campaign instances (work objects of PegaMKT-Work) are moved from Dev to Live environment, the campaign is not able to start if the PR(program run)ID is already present (e.g. PR-1324). When I try to reschedule again it is trying to create PR-1325, if 1325 is also present campaign is not starting, if I retry to reschedule again, it is creating PR-1326. Like this way until the number which is not generated occurs, the campaign is not starting.
How can I change the sequence number of PegaMKT-Work objects?
Durgarao J.
