Verizon Data Services
Last activity: 6 Sep 2017 5:07 EDT
Need to optimize a property through modify schema option ,but the property is not coming in the list which has to be optimzed
I have to optimize two properties in work class . I am using the modify schema wizard which pega gives . I selected the table and clicked on set to visible but I am not getting the properties which I have to optimize .
I can directly run the script to create the columns in the table and save the class and database table instance , but pega recommends the above approach.
Please suggest how to optimize the properties through the modify schema option .
