Property change in DB, does not reflect in case
This is a silly question. If we change a property value (ex: pystatuswork) in the db directly for the case. the new status value is not reflected in the case. verified from DB the column value is changed successfully for the record. whereas the case shows old value only.
question is what feature in pega is preventing such dubious methods(changes made directly in DB) to not reflect in the value in the case.
version: prpc 6.1sp2
regards
Tarun
***Edited by moderator, Maryrita: moved to Product Support from Applications***
