TATA Consultancy Services
Last activity: 13 Oct 2017 5:49 EDT
How to set minimum size of Harness on loading?
Hi Team, I am using PRPC 7.2.2 & 7.3 version.In MyCase portal the fileter option not showing properly when the row count(1 to 9) is very less. Please find the attached screen shot. The Portal Configuration below pyCaseManagerPortal> Screen Layout with Header option> Header Have Separate Section-pyPortalContent> Body Section have Dynamic Container(Dynamic Container have Harness-pyDashboard7 Configured with Size to Content Option and Multi Document option Max Doc 16) Onclick of MyCase Icon the pyMyCase7 Harness replacing the Existing "pyDashboard7" Harness.
Please help me on this.
Muthu
Thanks for posting in PDN.In the above post I can see two scenarios ,one with filter option issue and the other with pyMyCase7 Harness replacing the Existing "pyDashboard7" Harness.
which issue do you need help for?
Harini
Thanks for you reply,
I need display the filter option properly . The Replacing harness working as expected.
Muthu
Can you uncheck the size to content option in dynamic container and verify.
If you still face the issue ,then please provide the snapshots of
1.Portal harness
2.Section with mycases
3.Grid configuration
(general,presentation,operation).
Harini
If am removed the size to content option, the Screen not loading, Its showing 30 of the screen.
Can you please share the snapshots of
1.Portal harness
Harini
Eduardo Menezes Lakindu Kariyawasam Cody Burrell
Hello, The post title (How to set minimum size of Harness on loading?) and the description are completely different. From the description the issue is with GRID component and not harness. Please clarify.
SOHAIL SHAIKH Dilrukshi Deegalla
