Sensiple Software Solutions
Last activity: 23 Sep 2017 12:35 EDT
Cannot render section
hi,
I'm having two sections named A and B.
I need to reuse the content from section B to A.
When opening the section A I'm getting error Like Cannot render section.
Could anyone help me with this?!
No.still it shows the same..but runtime there is no issue with that section.Initially I added
No.still it shows the same..but runtime there is no issue with that section.Initially I added some fields to the process steps,by default section was created and named SelectOfficeEquipment_0.Later I need to add a data type named Facilities to that section.so the new section is created named SelectOfficeEquipment_0_Facilities.Here SelectOfficeEquipment_0 section has the cannot render section error.
Hi Santosh,
As you are using the section from the different class hierarchy you should provide the page context accordingly while adding the section. Can you share the properties of your subsection which is included in mainsection along with the data available in subsection.
Regards
Mahesh
Hi Mahesh,
I had given page context for main section and left it blank for subsection.
The properties of main section is a data type and the source is a reference data that was given by me manually,Will that be the cause of error?!
But runtime the section is displaying properly.
Thanks-Santhosh
It would be better to understand your implement if you could share your configuration screenshots Santosh.
Sure Mahesh. Please find the Screenshots below..Hope it will help you through..:)
Varna Badiger Jake Bloomfeld SAMEERA KANNURI Reshmi Upputuri Neela Rajapathar and 1 More
Santosh - which version of pega you are using. I tried to create Data type OTHO2I-Data-EmployeeDT and i am trying to refer this in my OTHO2I-CSSA-Work-Section1 repeat grid via Source -> Property and List/Group -> .Employees.
But i am not able to use the .Employees in this section as shown in the attachment, so can you checkout the Section 2 and see if you are able to save it with this configuration.
Yes.Now I'm able to save with this configuration.
Thanks.
So you mean to say that the issue has been resolved?
J.P. Morgan Services India PVT Ltd
It could be related to the ruleset versions of both the sections.
What is the behavior on runtime? Are you seeing any issue at that time?
Thanks- Neha
Priyanka Patha
Hi Neha,
I've checked that both sections are in same ruleset.
At runtime it was running correctly,Only when I'm opening it on application explorer I'm getting this error.
Thanks- Santhosh
Could you please provide the screen shot of two sections ?
Are both in Work- class hierarchy ? or one is work- and another one is from Data- ?
yeah..Both sections in work class.just see the screenshots below.:)
