![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689981000/7e436693-347f-4c3d-9ea0-7ac79e3ea06d.jpg?itok=ICFPkBdU)
LeasePlan Digital B.V.
Last activity: 9 Aug 2017 4:26 EDT
Connection Factory
Trying to use same connection factory for Connect JMS and JMS Listener. Its not working and giving error client is already in use. Please suggest if we can use same connection factory for connect jms and listener running on same node.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689980000/6b73fef3-95fe-4476-92a0-e634d6a0fe28.jpg?itok=eO_uceTm)
BUPA
Hi Vishal,
Can you pls elaborate your problem with exact error message? We are using same connection factory both for connector and listener.
Please see attached screen shot. We have got one connection factory and we are trying to build Connect JMS and JMs listner for same connection factory.
BUPA
This looks like application server problem and not a pega specific problem. We are using Websphere application server and same connection factory is being used both in listener and connector. Pls check with Pega Support to get a solution.
Can you please help us stack trace and configuration screen shots for suggesting the possible update or solution.
Can we set this com.webmethods.jms.ClientIDSharing=true” in Pega , if yes how ?
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689989000/e68f0e72-3351-415a-8922-185e73fa77f4.jpg?itok=lcGeM-2x)
Virtusa IT Consulting
AE
Probably you can set the above value as JVM properties, Try setting it as -Dcom.webmethods.jms.ClientIDSharing=true as JVM argument at your server.
