Virtusa Corporation
Last activity: 21 Jul 2017 3:43 EDT
Page-Set-Messages not shown in confirm and Review harness
I have a repeat grid sourced using a page list. And I have a button which on cliking runs an activity. In that activity, I am using a when condition looping over the page list to check for a text box displayed in a column in repeat grid. If the value of the text box property is empty, I am setting a property-set-message to show "This field cannot be blank". When in perform harness, the message is set and shown above the textbox. But when in a confirm or review harness, the message is not shown and just an small red triangle with shown inside textbox while on hovering over it only I could see the message. I want to display the message in the same way as in perform harness. Any help is much appreciated!
Thanks in advance.
Hello Ganapathy,
Could you please try performing the following steps.
1. Add an error section to the harness which will be used to display the message.
2. If the above still does not display the error, create a non-auto generated section and include it in the harness.
Enter the below code in that section.
<script>
pega.u.d.KeepPageMessages="true";
</script>
Hope that helps.
