Accenture
PCS framework dependency on Pega platform
We are working for a Healthcare client. The application is currently using PCS 7.13 framework on Pega 7.1.9. They have another environment with Pega base version as 7.2.2. As per PCS 7.13 release notes, prerequisites section states that - "The software required to install and run the framework includes: Pega 7.1.9 or higher". Does that mean that the same FW (PCS 7.13) will work on this new environment (Pega 7.2.2)?
Yes PCS 7.1.3 should work with Pega 722.
However when ever you update Pega Platform we strongly recommend to take the latest Pega 722 supported version of PCS.
