![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2024-09/6746cb12-7780-4a34-a582-ce89dee54910.jpg?h=e18f4243&itok=5NR45Y30)
Royal Bank of Canada
Last activity: 10 Aug 2017 6:56 EDT
Need Date type Circumstance clarification
This is just a clarification question on circumstance. When I create two circumstance specialized rules with start and end dates, one from April to September and other from June to August in the same version, then for July time period which one will be picked?
Thanks in Advance.
Updated: 4 Aug 2017 11:50 EDT
Virtusa Consulting UK
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689980000/6b73fef3-95fe-4476-92a0-e634d6a0fe28.jpg?itok=eO_uceTm)
BUPA
I think one from April to September
Hi Swarnendu , thank you for the reply but could you please give me the reason?
![](https://accounts.pega.com/sites/default/files/pega-user-image/35/REG-34855.png?source=PUMINIT)
I would look at the generated java. I think it will probably depend on which you create first (just a guess). What will happen is you'll get code along the lines of...
if(circumstance1 == true)
circumstance1 version
else if(circumstance2==true)
circumstance2 version
else
base version
Since both circumstances would evaluate to true, the first one in the code (and I'm not sure how the code generation orders things, though I expect we don't make any promises either way) will win.
Mike
Durga Vara Prasad Narayana Rao Bali
Thanks Mike for the clarification.
Thanks Kautukshet for the answer and clarification given.
Glad it helped.
