How to ZIP WO's from application, needs to purge same WO's from PRPC DB and need to import that archive ZIP to client server
We have a requirement to create archive zip file from PRPC application based on specific days and needs to store the ZIP in client server and then need to purge the WO's from PRPC DB.
we are using 6.3 SP1
Hi Ravi,
You can use the Purge and Archive wizard provided by Pega.
DesignerStudio > Systems > Operations > Purge and Archive
Archiving work item data enables you to retrieve them if needed for audits or for backups. Note the following:
