Genome
Last activity: 21 Jun 2017 13:08 EDT
PRNodeImpl init failed - java.lang.ArrayIndexOutOfBoundsException
When we restart a node, we are getting java.lang.ArrayIndexOutOfBoundsException. Any idea on what is causing this issue?
Pega Version:7.1.8
Weblogic: 12C, DB: Oracle Proprietary information hidden
Veera
Genome
We are not sure on what exactly caused above issue. After clearing cache (including extract marker) from the application server and DB, we were able to start the nodes. Apologize for not updating the thread earlier.
Genome
Additional logging.
Additional logging.
2017-05-31 18:16:34,849 [ stage2cpp127] [ STANDARD] [ ] [ ] (.DeclarativePageDefinitionImpl) ERROR - Error occured while preloading the data page RULE-DECLARE-PAGES DECLARE_AUTHPOLICIES #20130919T004035.555 GMT. Skipping this data page
2017-05-31 18:16:34,981 [ stage2cpp127] [ STANDARD] [ ] [ ] (.DeclarativePageDefinitionImpl) ERROR - Error occured while preloading the data page RULE-DECLARE-PAGES DECLARE_CACHEDDATASYSTEMSETTINGS #20130919T003156.719 GMT. Skipping this data page
2017-05-31 18:16:35,087 [ stage2cpp127] [ STANDARD] [ ] [ ] (.DeclarativePageDefinitionImpl) ERROR - Error occured while preloading the data page RULE-DECLARE-PAGES DECLARE_DIMENSIONCACHEHASHMAP #20130920T104324.338 GMT. Skipping this data page
2017-05-31 18:16:39,195 [ stage2cpp127] [ STANDARD] [ ] [ ] (.DeclarativePageDefinitionImpl) ERROR - Error occured while preloading the data page RULE-DECLARE-PAGES DECLARE_DSMCONFIG #20130920T104324.632 GMT. Skipping this data page
2017-05-31 18:16:39,289 [ stage2cpp127] [ STANDARD] [ ] [ ] (.DeclarativePageDefinitionImpl) ERROR - Error occured while preloading the data page RULE-DECLARE-PAGES DECLARE_GLOBALSIMULATIONPAGE #20130919T001252.670 GMT. Skipping this data page
2017-05-31 18:16:39,376 [ stage2cpp127] [ STANDARD] [ ] [ ] (.DeclarativePageDefinitionImpl) ERROR - Error occured while preloading the data page RULE-DECLARE-PAGES DECLARE_INTEGRATIONCLASSES #20130919T020009.298 GMT. Skipping this data page
2017-05-31 18:16:39,655 [ stage2cpp127] [ STANDARD] [ ] [ ] (.DeclarativePageDefinitionImpl) ERROR - Error occured while preloading the data page RULE-DECLARE-PAGES DECLARE_OUTCOMEDIMPAGE #20130920T104618.652 GMT. Skipping this data page
Are you ever able to start these nodes?
Can you please provide the complete startup log? Often there is a message before the error that will help us determine what the issue is.
Genome
Verizon
Genome
Refer below thread for the tables.
https://collaborate.pega.com/question/deleting-db-cache-after-rules-import-mandatory
