Coforge DPA Aus Pvt Ltd
Posted: May 16, 2017
Last activity: May 30, 2017
Last activity: 30 May 2017 6:19 EDT
Switch Application Function in pzAppMenu
i am using switchApplication function and passing one parameter accessGroup with coloumn from db for which we also created access group in pega too.i am doing something wrong it isnt working. any suggestions ?
You could trace the switch-application menu item that is available on the developer portal and compare what it does with what your implementation does. Does that give you useful info?
