Difference between property type and cell properties type
I have a property "amount" set as "pxTextInput". The ruleset is locked so I can't change and it is used by different rulesets that it is not easy to change the property type.
In one of the section the property shows as "Text Input" under cell properties. Can I change it to "Currency" so users can only type numeric values? The actual property type will remain the same as "pxTextInput" but under section the cell properties will have "currency".
Do cell properties only affect UI ? Anyone see if this could be an issue?
