Launch Review Harness on Discard
Requirement: on Click of button discard we want to discard changes and launch review harness.
Issue: Though the review harness is launched on discard, the data reflects the changes. But, on refresh changes are discarded.
Hi karua2,
Could you add a screenshot of the button configuration used? (Actions tab preferably).
What if you would add a Cancel action for OnClick event?
Evita.
Hi Evita,
If I only use cancel option, changes are discarded but I want the Work object to be shown in Review mode. Please find attached configuration.
Abhishek
Try calling an activity to first discard the changes then a show-Harness method to launch review.
Hi I tried to call the activity Show-harness and do a refresh. No luck. Is there any specific activity to discard changes ?
Take a look at CancelAndDisplayWork activity . May be that can help.
Copy the same action as Refresh.
i.e. Refresh current harness + Check Disable Submit on refresh + Specify Activity
For activity Make a copy of RefreshOnConflicts (let's say ReviewAction) and only keep last two steps which does Show-Harness by mentioning the param.Purpose as Review.
Let us know if you need more information on this.
Thanks for the reply. With your approach too i need to do a refresh on the review harness to see the changes are discard.
Disable submit on refresh check should already take care of not persisting the data and will wipe from clipboard. Are you noticing the entered data on UI even after refresh ?
Yes. I see the changes not being removed. But if I do a refresh again, then I don't
Could you share your exact configuration if possible? I tried the same with same config and it is working.
Hi Karua2,
Any update on this. I have similar requirement. Please let me know if you have solution for this.
Krishna Chaitanya
