How to Disable AssignmentLinks in Review harness
In the workbasket rule form ,you can mention the AccessRoles ...so that those without roles will not be able to open the assignment.
Srijith.
Check out the security tab of the flow action rule.
https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm
Best Regards,
Mounika
There is one more way, You can also use OOTB when rule "pyWorkActionsIsPerform" to disable the links in Review harness.
