How to configure the directory for filesystem HA passivation
I'm trying to configure the directory that Pega uses for filesystem HA passivation, but I'm having no luck. Strangely the High Availability Guide is very light on for actual detail, it talks about filesystem passivation but doesn't actually tell you how to configure it.
https://docs.pega.com/pega-722-high-availability-administration-guide
This page in the help mentions the settings to set to use either database passivation or filesystem passivation but again doesn't tell you how to configure the directory for filesystem passivation.
https://community.pega.com/sites/default/files/help_v722/procomhelpmain.htm
I have database passivation working correctly, but I would like to get crash recovery working, which from my reading, requires filesystem passivation to be configured.
Reading the Crash Recovery help page talks about setting "storage/class/passivation/rootpath" to be the directory where passivation data is written to, however when I set that, nothing was written to that directory. By default, pega seems to write file passivation data to the temp directory, which doesn't make sense to me as that won't help other nodes in the cluster use that passivation data.
https://community.pega.com/sites/default/files/help_v722/procomhelpmain.htm availability/crash recovery/eng-high-availability-server-crash-recovery-con.htm
I should also mention that I am triggering a Quiesce via JMX before the Pega server is shutdown
What am I missing?
Joel
What am I missing?
Joel
***Updated by moderator: Lochan to add documentation bug ID***
***Updated by Moderator: Marissa to add Doc Bug group tag***
