High availability - filesystem vs. database choice
Hello
I am getting up to speed on HA configuration. I am reading the 7.22 Administration guide, and in the Shared storage section, I find the following statement:
When high availability is enabled, database passivation is used as the default passivation method, in
which the database handles all storage requirements.
However, if you decide to instead use filesystem passivation, you must select a shared storage solution
and need to implement the shared storage API to integrate with the Pega 7 Platform.
Looking for some guidance on what factors would drive you to use filesystem passivation vs. database passivation. Database seems like the natural choice.
TIA
Diane
