Pega High Availability
How Pega handle the high availability. i.e. I have 3 nodes having DDS ( Cassandra ). i run some job and the first DDS node was used for job processing. Somehow that node goes down and job is failed in that node.
Will there be no automatica failover . Job moved to another remaining cassandra node?
how that will be handled. How pega platform Application level failure will be handled in case any issue with node type
***Edited by Moderator: Pooja to change content format from Discussion to Question***
