Error initializing raw filesystem configuration
We need help to resolve this issue on Pega 7.1.8 intallation / Websphere Z-os.
ERROR - Error initializing raw filesystem configuration
com.pega.pegarules.priv.storage.FileStorageException: No write access to root path: /
2016-08-03 16:54:01,824 [ server.startup : 0] [ ] [ ] [ ] (les.storage.FileStorageManager) ERROR - Error initializing raw filesystem configuration
at com.pega.pegarules.storage.fs.direct.FilesystemStorage._init_privact(FilesystemStorage.java:117)
at com.pega.pegarules.storage.fs.direct.FilesystemStorage.<init>(FilesystemStorage.java:80)
at com.pega.pegarules.storage.FileStorageManager.getStorageImplementation(FileStorageManager.java:198)
at com.pega.pegarules.storage.FileStorageManager.init(FileStorageManager.java:137)
at com.pega.pegarules.deploy.internal.archive.ParUtilsImpl.setStageDirectory(ParUtilsImpl.java:220)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:511)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:165)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:138)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.doStartup(EngineBean.java:121)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:95)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:56)
at java.lang.reflect.Method.invoke(Method.java:620)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:245)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.doStartup(EngineBeanBoot.java:130)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.doStartup(Unknown Source)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitialized_privact(WebAppLifeCycleListener.java:311)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener.contextInitialized(WebAppLifeCycleListener.java:218)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at com.ibm.ws.webcontainer.webapp.WebApp.notifyServletContextCreated(WebApp.java:1704)
at com.ibm.ws.webcontainer.webapp.WebAppImpl.initialize(WebAppImpl.java:411)
at com.ibm.ws.webcontainer.webapp.WebGroupImpl.addWebApplication(WebGroupImpl.java:88)
at com.ibm.ws.webcontainer.VirtualHostImpl.addWebApplication(VirtualHostImpl.java:169)
at com.ibm.ws.webcontainer.WSWebContainer.addWebApp(WSWebContainer.java:749)
at com.ibm.ws.webcontainer.WSWebContainer.addWebApplication(WSWebContainer.java:634)
at com.ibm.ws.webcontainer.component.WebContainerImpl.install(WebContainerImpl.java:426)
at com.ibm.ws.webcontainer.component.WebContainerImpl.start(WebContainerImpl.java:718)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.start(ApplicationMgrImpl.java:1177)
at com.ibm.ws.runtime.component.DeployedApplicationImpl.fireDeployedObjectStart(DeployedApplicationImpl.java:1370)
at com.ibm.ws.runtime.component.DeployedModuleImpl.start(DeployedModuleImpl.java:639)
at com.ibm.ws.runtime.component.DeployedApplicationImpl.start(DeployedApplicationImpl.java:968)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.startApplication(ApplicationMgrImpl.java:776)
at com.ibm.ws.runtime.component.ApplicationMgrImpl$5.run(ApplicationMgrImpl.java:2195)
at com.ibm.ws.security.auth.ContextManagerImpl.runAs(ContextManagerImpl.java:5477)
at com.ibm.ws.security.auth.ContextManagerImpl.runAsSystem(ContextManagerImpl.java:5603)
at com.ibm.ws.security.core.SecurityContext.runAsSystem(SecurityContext.java:255)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.start(ApplicationMgrImpl.java:2200)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.start(CompositionUnitMgrImpl.java:435)
at com.ibm.ws.runtime.component.CompositionUnitImpl.start(CompositionUnitImpl.java:123)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.start(CompositionUnitMgrImpl.java:378)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.access$500(CompositionUnitMgrImpl.java:126)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl$CUInitializer.run(CompositionUnitMgrImpl.java:984)
at com.ibm.wsspi.runtime.component.WsComponentImpl$_AsynchInitializer.run(WsComponentImpl.java:502)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1881)
2016-08-03 16:54:01,889 [ server.startup : 0] [ ] [ ] [ ] (ervlet.WebAppLifeCycleListener) ERROR - Exception during startup processing
com.ibm.ejs.container.UnknownLocalException: nested exception is: com.pega.pegarules.pub.PRRuntimeException: Unable to initialize raw filesystem access
at com.pega.pegarules.storage.FileStorageManager.init(FileStorageManager.java:140)
Caused by:
Hi Fabio,
Can you verify if there are write permissions to application server user to the root path?If not can you provide the permissions and check.Hope this helps you to resolve the issue.
