Split for Each - Question
How can we achieve using Split for each, let's assume we need to create 10 assignments
1) the Case has to flow forward only when all the assignments are approved
2) If one of the assignment is rejected, we need to cancel all the assignments and return to the case to Originator..
Is there any easy way to achieve #2, #1 seems to be straightforward.
NM
