SINARMASMSIGLIFE
ID
Failed to find a 'RULE-OBJ-MODEL' with the name 'PYDEFAULT' that applies to '@baseclass'
hi,
I found a problem with this issued, before I found an error like this.
and then i using SMA (as recommended in this link) : https://collaborate.pega.com/question/failure-opening-rule-instance-error-baseclass
but not successful ( still cannot open),
and then i delete class from refactor but still not deleted.
hi,
so i create again this class, but when at last step ( after click finish) , there are something error .
i got error message "PYCOMMIT error :Failed to find a 'RULE-OBJ-MODEL' with the name 'PYDEFAULT' that applies to :'ClassPath.PYDEFAULT".
after that, i got error whenever try to open others class .
there is message error in tracer :
Failed to find a 'RULE-OBJ-MODEL' with the name 'PYDEFAULT' that applies to '@baseclass'. There were 1280 rules with this name in the rulebase, but none matched this request. The 1280 rules named 'PYDEFAULT' defined in the rulebase are:
1252 related to applies-to class '@baseclass', but were defined on subclasses: {Data-MO-DDF-Compose, Rule-Parse-Infer, Rule-Test-Unit-Case, PegaAccel-Task-AttachmentCategory, Rule-Template-Word, Log-DataAccessAudit, Embed-Skin-Component, PegaAccel-Task-Harnesses, PegaGadget-InformationMashup, Data-Corr-PhoneText, Rule-Service-MQ, Embed-SelectedContextAPI-AddRow, Data-Admin-Security-Keystore, Embed-DesktopAPI-ShowWorkList, PegaFW-Data-SocialFilter, Embed-SelectedContextAPI-RunDataTransform, Data-MO-DSM-StrategySet, Embed-FConditions, PegaAccel-Task-ImportExport-Requirements, Embed-Stencil-Presentation-Modifier,...}.
28 inaccessible because their availability was {No, Withdrawn, Blocked}.
can you/anyone help me ?
