EIA
Last activity: 17 Mar 2017 11:53 EDT
Just trying to create an application
I am trying to create and application and have it show up in designer studio. I can't get there. I wish Pega allowed for useful tutorials on youtube but apparently greed is a thing even after companies pay for the software.
***Updated by Moderator: Marissa to move from Applications to Product Support; updated categories***
Hi Charles,
As per the attached screenshot it looks like you had created an application APP_CG with [email protected] user and still you are looking for the application in the [email protected] user login.
Once the application is created you will have the default user accounts like administrator/manager/user will be created.
You can find these operators in Records > Organization > Operator ID (displays list of all operators)
If you login with the respective admin user account then you can able to see the application which is created.
Regards
Mahesh
Updated: 9 Mar 2017 2:29 EST
Accenture Australia
Hi Charles,
If your need is creating a new application means you can click on the application and we will find an option called new application then the app wizard will create a new application based on the built on.
Thank you
EIA
I've figured that out, but I don't know where to go from there. The application does not display, I can't open it from the navigation menu.
EIA
I've added an image. I made an application called 'APP_CG' and it's not showing up
Hi Charles,
You will want to make sure your operator record has an access group for your new application. Then when you log out and back in you should see the application available in the list.
Hi Charles,
Regards
Mahesh
EIA
Thanks! I will try this
Charles,
Also you can cross check whether your application is available or not from Records > Application Definition > Click on Application(it will display the list of created applications). Hope this might be helpful to you.
Regards
Mahesh
