Action that failed GeneralFail For class @baseclass
I got error when tried to create new case type. See below.
Can you help me?
Alfian
Can you help me?
Alfian
hi ,
this case is already clear , as a colleague of Alfian I'll help explain the problem.
Hi ,
Probably, you can try checking in the logs for the root cause, or post them here.
Can you please check whether you have defined all sections and properties with right pages & classes defined in GenerateFail Section.
If yes, try running static assembler in designer studio for your application whether it is throwing any errors or not.
Prudhvi
hi ,
