Wellsfargo
Last activity: 22 Mar 2017 11:52 EDT
Word Document Genertor
As we have a PDF generator, I want a WORD document generator, if any one knows please help me with this
Hi Sangamesh,
In order to generate the word document for the application requirements you can go to Designer Studio > Application > Tools > Document (This section contains Application Profile/Application document/Specification document)
If you want to generate the Application document then you can select Application document in Document section then select the configuration as per your requirement and click on Generate document button will result you an application word document download.
Hope this will help you in your requirement.
Regards
Mahesh
Wellsfargo
Need help
Hi Sangamesh,
If you are looking for the generation of the word document from the content like page list, table format dynamically then look into this discussion over here.
If not could you elaborate your requirement with your usecase for more understanding.
Regards
Mahesh
Wellsfargo
Thank you...
Hi Sangamesh,
I found a sample tutorial video related to the application document which does the same word document generation over here. Hope this might be helpful to you.
Regards
Mahesh
Blue Rose Technologies GmbH
BE
Please have a look on the below article :
Thanks.
Wellsfargo
Thank you for the help I'll try this
Wellsfargo
Elaborating the question how an application or requirements can be generated or converted to word.
Hi Sangamesh,
Regards
Mahesh
