Murex
LB
Last activity: 7 Feb 2017 6:38 EST
Trace a Standard agent whose Pattern is Startup
Is there a way to trace a Standard agent whose Pattern is Startup?
Currently in the System Management Application, the above agent is not marked as runnable and it cannot be Started/restarted/stopped.
Thank you,
Mariane
Hello Mariane ,
Please go through below PDN article hope it helps .
https://community.pega.com/sites/default/files/help_v722/procomhelpmain.htm
Arun
Hi
Are you passing the required parameter which can trigger the agent ?
Murex
LB
Hello Santanu,
Thank you for your reply:)
Yes I am passing the required parameter that triggers the agent. I am doing so by calling the method Queue-For-Agent and giving it the agent name and ruleset as such:
where the Agent "LaunchConnectREST" is a standard agent as such:
Thank you,
Mariane
Can you try deleting the instance of Data-Agent-Queue, if any has been created and restart the system, to check, if the instance created again,and is reflecting the info of Rule-Agent-Queue ?
Murex
LB
Hello Haritha,
By deleting the instance of Data-Agent-Queue do you mean the corresponding Agent Schedule ?
Mariane
Yes. Because, it gets recreated, once the agent runs at the startup.
BlueRose Technologies
Hi Maraine,
May I know which prpc version you are using at your end.
Murex
LB
Hello Prudhvi,
We are using version 7.2.1
Thank you,
Mariane
