Want to connect to SMA to configure a DB but not successful
Guys,
I wanted to connect to SMA to config a DB but never could get it done or could not find the SMA war file to deploy.
However I could get DB driver installed with out SMA. See below if that is what you want to do.
https://www.pegaxchange.com/2016/04/23/access-mysql-db-from-pega-7/
(3rd point onwards) 3. Configuration of Connection to MySQL Server in Pega 7 PRPC
regards
***Moderator Edit: Vidyaranjan | Branched comment from thread to create a new one, also updated Categories***
Sorry for the confusion.
I needed to access SMA to install MYSQL driver to make the connection. Personal edition did not have SMA bundled so I had to find other ways.
I managed to install the driver as per the link given in my original post and re-shared for others.
Hope this clears the doubt.
This thread can be closed.
