Using MQ connector in Pega 7.1.8
Hi Pega Support Team,
We have Pega Platform 7.1.8 and IBM WebSphere Application Server Proprietary information hidden.
When we trying to connect to external MQ server, we create MQ server instance, MQ connector in Pega to enable the connection.
Af first, we always have "MQException cannot be resolved" error. To solve it, we place the "com.ibm.mq.jmqi.jar" file on the disk of the application server and update the dynamic system settings of "compiler/defaultPaths" to point to that jar file. Then the problem got solved.
However, it is more like a workaround instead of a formal solution, especially for production environment.
And per our understanding, for IBM WAS Proprietary information hidden, it is not necessary to include any additional jar file outside Pega.
Could you please advise us which is a formal way or best practise for solving this problem? Or do we need to open a SR to apply for a hotfix for this problem?
Thanks and Regards,
Yang
