Unitedhealth Group
Last activity: 22 Feb 2017 10:50 EST
Automated Deployment - Application rule not getting overridden
Hi ,
We are using the scripts from Pegasystems for performing automated deployments using a tool named XL Deploy. All rules / data instances are getting migated to a target environment but the Application rule is not getting overridden. If we export the archive manually using import wizard, the application rule is getting overridden.
Note that we are explicitly including the Rule-Application instance in the 'Individual instances to include' section of the Product rule.
We can see the following entries in the log:
[pega:propertyparser] import.existing.instances=override
[java] 2017-01-09 06:19:14,641 [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Total instances in archive: 5
[java] 2017-01-09 06:19:14,641 [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Instances imported: 5
Any clue on why the application rule is not getting overridden?
Pardha
