Vodafone Group
DE
Showing properties in Application designer
I'm following the exercises of System Architect Essetials 7.2.
In the excercise for defining declare expression rules: Automatically updating the total cost of benefits I've the following problem:
I've defined the new properties in the data model tab of the case explorer, as describe in the solution but I can't perform the step:
Create a declare expression rule for the Total benefit cost property
I don't see the elements in the application explorer. The only element available in Application explorer under:
Benefits Enrollment > Data Model > Property
is Dependents
What must I do to display the other properties here, in order to define the expressions?
Thank you very much
