HCL
Last activity: 30 May 2017 8:00 EDT
Application Design
Hi Team,
As per the Attachment,
Given answer is contradicting with the below statement.
" When the Availability of a rule is set to Withdrawn, the rule is removed from the list of rule candidates.
Finally, all other rule candidates that match the Apply to: class, the ruleset name and major version
number, the rule purpose, and any qualifiers of the rule set to Withdrawn are removed from the list as
well".
Not sure where my understanding is going wrong
Hi Tejaswini,
If you observe the rule set stack of application, highest version of RulesetC is "01-17-50".
Even though it is withdrawn in "01-17-99", will not be visible to the application (withdrawn rule).
So the highest version of rule available and visible to application will from 01-09-12.
Hope it helps.
Ananda Bhat
