Need help in converting docx to pdf using docx4j api
The following exceptions are recorded while trying to convert docx to pdf.
Pega 7.2
Exceptions:
Show More
Pega 7.2
Exceptions:
2016-12-26 17:22:05,849 [fault (self-tuning)'] [TABTHREAD5] [ ] [testapp:01.01.01] ( org.docx4j.XmlUtils) ERROR XXX.XXX.X.X|XXX.X.X.X user26 - Cannot convert argument/return type in call to method 'org.docx4j.convert.out.fo.XsltFOFunctions.createBlockForPPr(reference, node-set, string, result-tree)'
2016-12-26 17:22:05,851 [fault (self-tuning)'] [TABTHREAD5] [ ] [testapp:01.01.01] ( org.docx4j.XmlUtils) ERROR XXX.XXX.X.X|XXX.X.X.X user26 - Cannot convert argument/return type in call to method 'org.docx4j.convert.out.fo.XsltFOFunctions.createBlockForRPr(reference, node-set, node-set, result-tree)'
2016-12-26 17:22:05,851 [fault (self-tuning)'] [TABTHREAD5] [ ] [testapp:01.01.01] ( org.docx4j.XmlUtils) ERROR XXX.XXX.X.X|XXX.X.X.X user26 - Cannot convert argument/return type in call to method 'org.docx4j.convert.out.common.XsltCommonFunctions.fontSelector(reference, node-set, node-set, node-type)'
2016-12-26 17:22:05,853 [fault (self-tuning)'] [TABTHREAD5] [ ] [testapp:01.01.01] ( org.docx4j.XmlUtils) ERROR XXX.XXX.X.X|XXX.X.X.X user26 - Cannot convert argument/return type in call to method 'org.docx4j.convert.out.fo.XsltFOFunctions.createBlockForSdt(reference, node-set, string, result-tree, string)'
2016-12-26 17:22:05,854 [fault (self-tuning)'] [TABTHREAD5] [ ] [testapp:01.01.01] ( org.docx4j.XmlUtils) ERROR XXX.XXX.X.X|XXX.X.X.X user26 - Cannot convert argument/return type in call to method 'org.docx4j.convert.out.fo.XsltFOFunctions.createBlockForSdt(reference, node-set, string, result-tree, string)'
2016-12-26 17:22:05,855 [fault (self-tuning)'] [TABTHREAD5] [ ] [testapp:01.01.01] ( org.docx4j.XmlUtils) ERROR XXX.XXX.X.X|XXX.X.X.X user26 - Cannot convert argument/return type in call to method 'org.docx4j.convert.out.fo.XsltFOFunctions.createInlineForSdt(reference, node-set, result-tree, string)'
2016-12-26 17:22:05,856 [fault (self-tuning)'] [TABTHREAD5] [ ] [testapp:01.01.01] ( org.docx4j.XmlUtils) ERROR XXX.XXX.X.X|XXX.X.X.X user26 - Cannot convert argument/return type in call to method 'org.docx4j.convert.out.common.XsltCommonFunctions.notImplemented(reference, node-type, string)'
2016-12-26 17:22:05,857 [fault (self-tuning)'] [TABTHREAD5] [ ] [testapp:01.01.01] ( org.docx4j.XmlUtils) ERROR XXX.XXX.X.X|XXX.X.X.X user26 - Cannot convert argument/return type in call to method 'org.docx4j.convert.out.common.XsltCommonFunctions.notImplemented(reference, node-type, string)'
2016-12-26 17:22:05,858 [fault (self-tuning)'] [TABTHREAD5] [ ] [testapp:01.01.01] ( org.docx4j.XmlUtils) ERROR XXX.XXX.X.X|XXX.X.X.X user26 - Cannot convert argument/return type in call to method 'org.docx4j.convert.out.common.XsltCommonFunctions.updateComplexFieldDefinition(reference, node-type)'
2016-12-26 17:22:05,859 [fault (self-tuning)'] [TABTHREAD5] [ ] [testapp:01.01.01] ( org.docx4j.XmlUtils) ERROR XXX.XXX.X.X|XXX.X.X.X user26 - Cannot convert argument/return type in call to method 'org.docx4j.convert.out.common.XsltCommonFunctions.notImplemented(reference, node-type, string)'
2016-12-26 17:22:05,860 [fault (self-tuning)'] [TABTHREAD5] [ ] [testapp:01.01.01] ( org.docx4j.XmlUtils) ERROR XXX.XXX.X.X|XXX.X.X.X user26 - Cannot convert argument/return type in call to method 'org.docx4j.convert.out.common.XsltCommonFunctions.notImplemented(reference, node-type, string)'
2016-12-26 17:22:05,861 [fault (self-tuning)'] [TABTHREAD5] [ ] [testapp:01.01.01] ( out.common.AbstractExporter) ERROR XXX.XXX.X.X|XXX.X.X.X user26 - Exception exporting package
Code:
try {
java.io.InputStream is = new java.io.FileInputStream(new java.io.File("/temp/testing.docx"));
org.docx4j.openpackaging.packages.WordprocessingMLPackage wordMLPackage = org.docx4j.openpackaging.packages.WordprocessingMLPackage.load(is);
java.io.OutputStream out = new java.io.FileOutputStream(new java.io.File("/temp/HelloWorld2.pdf"));
org.docx4j.Docx4J.toPDF(wordMLPackage, out);
} catch (Throwable e) {
oLog.error("Exception while creating pdf:"+e.toString());
***Updated by moderator: Lochan to remove proprietary information; add SR details***
Show Less
