Wells Fargo
Last activity: 7 May 2018 9:27 EDT
Personal Edition 7.2.2 , not able to access SMA getting 404 resource not available error
Hi, I have installed personal edition 7.2.2 recently and tried to launch the SMA using ie. Getting the error as HTTP Status 404 - /prsysmgmt,
description The requested resource is not available.
Please let me know how to fix this issue. Appreciate your support on this.
Vijay.
***Moderator Edit: Vidyaranjan| Updated Categories***
***07/05.2018: Updated by Moderator: Lochan - Community Post has been closed to future commenting. Information will stay as it is archived for educational purposes. If you have the same or similar question, please click Write a Post and start a new discussion.***
Incessant Technologies
Hi
Could you please check SMA URL entry in URL Setting landing page. It should have same host and port as PRPC application. After this log out and login again before trying. Hope this might help.
Please check the attached image to set SMA URL in Desginer Studio.
Wells Fargo
Hi Rajesh , I have checked the URL setting and it is having the same host & port information. Attached the screen shot of the error page.
Unisys
I hope you have deployed the SMA after PRPC install. If not, do it so.[ you can read instructions for the same]
For Tomcat, you can check the deploy status in the tomcat manager. Start it if it is not already running.
-Praveen
Tech Mahindra
In addition to SMA, for Pega Help also there is a problem and other post says the lpallswHyd... Help URL will work. Doubt that as it is apperaing to be an internal URL to an org.
I feel the installation done from 115291_P722-PE.zip is not deploying / installing the SMA and Help war files.
Webapps directory screen shot from teh 7.2.2 PE is attached in comparison with PE 7.2.1.
Anupam Ghosh
Virtusa IT Consulting
AE
Is SMA working now after deploying manually in tomcat?
Hi Jayakumar,
Yes it is true that PE 722 does not brings SMA and help war installed with package. But manually you can do it if you need it. Goto Manage App of tomcat admin page and install corresponding war.
Allianz
DE
How can we get SMA and Help WAR files to deploy on tomcat?
Cognizant
Not sure about SMA but for help you can give Online help URL from below link.
https://pdn.pega.com/support-downloads/pega-help-systems
Allianz
DE
Yes i know Help can be accessible through PDN, the challenge is with SMA, you cannot download it separately, it comes in the distributive bundle. And it was not provided in the download of 7.2.2 Personal Edition.
Independent Contractor
Has anyone found solution for this ? I'm not able to access SMA in 7.2.2 either ? It throws 404 error.
I hope you are also checking for PE 722. If yes then PE 722 does not come with bundled SMA and help web app. SMA comes as part of PRPC media and if needed then you need to request PRPC media to get SMA.
Allianz
DE
Yes, you are right, i have now SMA and Help, I had to request them separately.
In the future, Pega will fix this and add SMA and Help in the PE 722.
Virtusa
Well I found prsysmgmt.war and put it in to tomcat/webapps folder. it worked.
if you also need it give me a email. i can try to send it. it is around 5 mb.
Updated: 7 May 2018 6:31 EDT
consultant org
Hello, Could you please send prsysmgmt.war file on PDN private message...... Thanks
<message edited by moderator>
Virtusa
Guys,
I wanted to connect to SMA to config a DB but never could get it done or could not find the SMA war file to deploy.
However I could get DB driver installed with out SMA. See below if that is what you want to do.
https://www.pegaxchange.com/tag/pega-7-external-database/
(3rd point onwards) 3. Configuration of Connection to MySQL Server in Pega 7 PRPC
regards
This comment has been branched out as a new node and the new thread can be followed here
Telstra
For help, Go to Designer Studio->System->Settings->URLS
Under resource URLs, for Online Help URL, add https://pdn.pega.com/sites/pdn.pega.com/files/help_v722
This should solve your help issue.
For SMA, If you have Pega 7.2.1 installed on your laptop, you can get prsysmgmt.war file from that installation folder and go to http://localhost:8080 and deploy that via tomcat. It worked for me. PM me if you don't know how to deploy a war file on tomcat.
Areteans
Hi Abhi... After loading http://localhost:8080 Please help me finding tomcat users to deploy prhelp and SMA. thank you.
Hi kriishna,
In order to get SMA you need to copy prsysmgmt.war and prhelp.war into webapps folder of tomcat server folder. so when you start the server those two war's are deployed. Type localhost:8080 in your browser and click manager apps to see prsysmgmt in running condition. If you need any help regarding the process please reply to me.
