CPF
SG
Last activity: 31 Mar 2017 17:04 EDT
Problem while creating application
Hi, when creating a application getting below error. How to solve this problem?
"** Error in cloning pyEndUser71 skin. PegaAccel-Task-ApplicationProfile 0 " |
***Moderator Edit: Vidyaranjan| Updated Categories***
What version of Pega are you using? I see the error generated from the pzCloneSkinAndPortals activity in the Pega-AppDefinition 07-10-17 and 07-10-21 ruleset versions. The first step in the activity does an Obj-Browse to get pyEndUser71 skin from the UI-Kit ruleset. Do you have the UI-Kit ruleset?
CPF
SG
Hi, I am using pega 7.1.9 version. and Yes I have UI kit rule set and version is UI-Kit-7:04-01-04
What is the built on application?
CPF
SG
PegaRULES
Can you please share complete PegaRULES logs when you try creation application and it fails?
CPF
SG
Still looking for solution
Updated: 31 Mar 2017 17:03 EDT
Pegasystems
is there a stack trace in the pega log file associated with that error?
