Wipro
Failed to Open PVS LSA 7.1.9 on Oracle Virtual Box
for everyone on the thread, you can try deleting /etc/udev/rules.d/70-persistent-net.rules, then restarting the VM.
shutdown the VM and set the VirtualBox network adapter to Bridged.
start the VM; do not worry if an IP address is not available.
login to the VM console with the username: root
password - install
enter the command: rm /etc/udev/rules.d/70-persistent-net.rules
reboot the VM with the command: shutdown -r now
After the VM restarts, enter the command: ifconfig
hopefully you will see an IP address for eth0
let me know you y'all get along.
eddie
Wipro
Wipro
And on IF Config I am getting these all stuffs,
I re installed the VM and reimported the Pega 7 from a fresh download too. But of No help.. I tried some Permutations and combinations on Network Settings too after doing some research on other Forums on VM Not starting .. Somebody please help..
Wipro
While trying to connect to the Host Network Settings , I am getting following errors :
Failed to open/create the internal network 'HostInterfaceNetworking-VirtualBox Host-Only Ethernet Adapter' (VERR_INTNET_FLT_IF_NOT_FOUND).
Failed to attach the network LUN (VERR_INTNET_FLT_IF_NOT_FOUND).
Result Code: |
E_FAIL (0x80004005) |
Component: |
ConsoleWrap |
Result Code: |
Component: |
ConsoleWrap |
Interface: |
IConsole {872da645-4a9b-1727-bee2-5585105b9eed} |
Wipro
I got the Solution : We have to modify the Settings in Windows as well as in Vm.. Please follow the step by step diagrams :
Wipro
First go through the steps mentioned in PVS2.jpg, then go to Port.jpg..
Wipro
No still not working.. only the URL got generated, nothing else.. Please help
I am also facing this issue. i get http://9080 on virtual box console. Please help.
@thals,
can you confirm the OS for your computer? Is it Windows 10?
eddie
password - install
eddie
DIBP
Hi Eddie
SSA7.2.1
VirtualBox v5.1.14
Windows 10 64bits
As per suggestion and I tried it out but it is still not working.
Please see attached the output in eth0.
I am looking forward to see your reply soon.
Sar
Accenture
Hi Eddie,
The solution worked for me, thank you.
-Ganesh
Tech Mahindra
Hi Eddie,
Same situation with me as well. I am also using Windows 10. When I try deleting the file, it says file not found.
Please help.
Subhajit
Coforge
If Bridge network is not working, you can use NAT,
NAT -> Click on Port Forward ->Add new rule-> Enter as shown in picutre.
Now access your prpc instance as http://localhost:9696/prweb/PRServlet
Aegon
This worked well for me - solved the problem I had due to trying to access the exercise system when connected to a VPN.
Amdocs
BR
The Port Forward solution works great for me! I had the same problem.
bank of america
Port forwarding worked for me on my windows 7 laptop with NAT
after i started VM, I used localhost:9696
Have you just applied the latest Windows 10 update if so have a look at this post:
