How to integrate with PDF in openspan 7.1
Is there any component to integrate with PDF & to read scanned documents or images is there any component like OCR in openspan either in older or earlier versions
Pega Robotics may be extended through the use of .NET components. If you have a use case that is not currently supported, you can write you own components to perform the function.
are looking for OCR feature from PRPC or Openspan?
Unfortunately, I don't believe Openspan can work with PDFs at this time.
Prava,
OpenSpan/Pega Studio does not support PDF integration at this time.
if openspan is not supporting PDF integration & OCR feature,then what is the solution incase if we have a requirement where we need to work with PDF Documents & suppose if we have arequiremnt where we need to read text from scanned PDF documents ,in that case we need OCR or Some PDF compoment is need which is not available in openspan,please suggest some solution for this.
PDF functionality is currently in development. It will not read scanned documents - only machine generated PDFs.
I will post something here when it is available.
Hi Jeff,
We have a requirement where thru openspan , we should interrogate a open a PDF document , then interrogate a particular section/text in the pdf and sends the information/text back to the calling system.
Can you please update on this as you told this part was under development ? Is the solution available in PEGA openspan 8.0 ?
Appreciate your quick response.
If you upgrade to the latest version of 8.0 this functionality will be present. This was introduced in 8.0.1028.
Hi Jeff. Thanks for quick response. We are using PEGA robotics 8.0. But still we are not able to interrogate a particular section/text of a PDF .
While interrogating we are not able to drag & drop the bull's eye on the desired text/section of the PDF. Are we missing any steps ? Can you please help us how to do this ?
Hi Jeff,
I just now checked the robotics studio version we are using . It is 8.0.1016 against the desired 8.0.1028 what you did mention .
Can you please let us know what we need to do to update it to 8.0.1028.
Hi Jeff,
We raised a PEGA SR to get the plugins needed to update our software version from 8.0.1016 to 8.0.1037 ( I believe this is the latest version of PEGA Robotics) . Sometime back we got the link to download below two files :
1. Robotic Automation Studio 8.0.1037 - 115431_PEGA_RAS ( 415 MB)
2. Robotic Automation Studio Plug-in - 115433_PEGARASP (71 MB)
Query
1. I am assuming that PDF reading issue fix is also available in 8.0.1037 ?
2. Do we need to do a fresh installation taking the above two software or is there any way we can just update it ?
3. We have already built a certain portion of code in 8.0.1016 version . After we move to 8.0.1037 , how can we move the code to 8.0.1037 version which developed in 8.0.1016 version ?
Thanks a lot .
You will need to install the newer version. It will overwrite your existing installation effectively upgrading it. When you open your solution in 1037, it will upgrade automatically. Please be aware this upgrade is likely one-way, so back up your solution beforehand.
Hi Chittaranjan
I have the same requirement now , as we get invoices in pdf format and got to OCR that data !! Did you get a solution which works for this ? Appreciate if you can share the steps as I am a newbie to RPA world !!
R
You may also refer this discussion link as a reference in the new thread
Thanks!
Hi Vidyaranjan
This is the URL of the new post -
https://collaborate.pega.com/question/ocr-pdf-information
Thanks,R
Today we saw "Reimagine Insurance Operations with Robotic Process Automation" webinar, virtusa/Pega showcased How to read and extract data from PDF file capability. can you please guide on this ?
