How to delegate local data storage to end user in Pega 7.1.7
Hi Team,
We have a requirement to delegate "Local Data Storage" so that end user should be able to update the records and not able to delegate "DataType - Local Data Storage" in Pega 7.1.7. "Delegate" or "Add to Fav" options are not available with respect to local data storages.
Could you please let me know how to delegate "Data Type - Local Data Storage" in Pega 7.1.7v?
Venkateswara Reddy.
Thanks for you response.
I have delegated local data storage list view to the user and its resolved my issue.
Thanks.
Please check the below post which can help you for your query,
https://collaborate.pega.com/question/pega-717-unable-delegate-datatype-local-data-storage
Bala
Hi Bala,
I have viewes the above post but we dont have option to delegate local data storages. Once we delegate only we can fetch right. Without delgating to the user how we can fetch delegated rule. Could you please provide some more info.
Venkat
Hi Team,
Could you provide more info on the above my query.
Venkateswara Reddy.
Hi Yerasu Reddy,
Here is the solution, hope it will help you. Go to the class of the particular data table of which you want to delegate. For that go to data icon and right click on the data table name then you will find the view definition option.Click on that it will open the class and there you will find the option in actions button as Add to favorites. So that you can proceed with that options giving access group. So that the operators who are under the access group will have the access for that data class and data table.
Thank you.
Hi Dileep,
Its not a data table. I am trying to delegate local data storage and not able to find the option to delegte it. LEt me know if you have any idea on this.
Thanks.
Hi Team,
I am trying to delegate local data storage and not able to find the option to delegte it. Could you please provide the info.
Thanks.
Hi Team,
Could you please provide info on the above query.
in 7.1.9 I could see.
In case if this is missing in 7.1.7, the functionality might not be there and got introduced in later version of PRPC. The best would be updating the PRPC version.
Thanks.
I have delegated the local storage to one access group. Instead of loading the records, its opening the class name.
Kindly suggest
Sravan Kumar K.
Yeah. I also saw the same issue. Anybody is having update on this. Pega version: 7.2.2
