JP
Last activity: 20 Dec 2016 6:14 EST
pyCaseAttachmentsWrapper does not show attachment link, case id, attachment category if "Work-.pyIncludeSubCases" set to "true"
I am using PRPC v7.2.1.
As attached image shows, pyCaseAttachmentsWrapper does not show attachment link, case id, attachment category if "Work-.pyIncludeSubCases" set to "true". Is this a known issue ? if so is there any work around or hotfix provided?
Below is the expected display of Attachments section
Steps to reporduce the issue.
1. Override pyDefault data transform of a case type then set ".pyIncludeSubCases" to "true".
2. Create a new case and then attache a File to it.
