Virtusa Corp.
Last activity: 29 Nov 2016 17:11 EST
Unable to install Pega 7.2.1 Personal Edition on Windows 10 due to CreateProcess error=216
When I try installing Pega PRPC Personal Edition 7.2.1 on Windows 10, it gives me the following error. I've tried a good number of times to install it and I get the same issue again and again.
BUILD FAILED
D:\Program Files\Java\pegaGuiInstallerTemp\build.xml:141: The following error occurred while executing this line:
D:\Program Files\Java\pegaGuiInstallerTemp\build.xml:19: Execute failed: java.io.IOException: Cannot run program "D:\Pega\PRPCPersonalEdition\pgsql\bin\initdb" (in directory "D:\Program Files\Java\pegaGuiInstallerTemp"): CreateProcess error=216, This version of %1 is not compatible with the version of Windows you're running. Check your computer's system information and then contact the software publisher
I've tried installing it with the latest version of JDK (jdk1.8.0_111) as well as the one (jdk1.8.0_66) provided with the Installer and it still gives me the same issue.
Appreciate if this issue can be addressed to.
