Ocbc Bank
SG
Last activity: 18 Nov 2016 10:01 EST
We are unable to check-out the Decision Data rule from agent.
I am unable to check-out the decision data rule from agent.
I followed below steps:
1. create agent rule and bypass the authentication.
2. create an activity for check-out the rule.
3. Call activity from agent.
After running the agent i got following errors. Please find below log messages..
com.pega.pegarules.pub.context.PRSecurityException:
RuleSetName is not specified at com.pega.pegarules.session.internal.authorization.SessionAuthorization.enableUpdateForRuleSet(SessionAuthorization.java:806)
at com.pega.pegarules.session.internal.authorization.Authorization.canUpdateRuleSet(Authorization.java:833)
at com.pega.pegarules.data.internal.access.Saver.checkSecurity(Saver.java:753)
at com.pega.pegarules.data.internal.access.Saver.saveDeferred(Saver.java:368)
at com.pega.pegarules.data.internal.access.DatabaseImpl.saveDeferred(DatabaseImpl.java:3967)
Can any one please advise on this. Thanks in advance.
Anil G
I have couple of questions below.
1. Is that ruleset open for check out?
2. Is Use Check-out? enabled in the Ruleset's Security tab?
3. Did you check the batch requestor has the rule checkout option?
