Infosys Limited
Error in SOAP response
Trying to create SOAP Service with parsing rules.
In Response tab, I am referencing the XML Stream rules. But it is showing that "Could not find the specified XML stream rule". But the rule exists.
Attaching the error screenshot.
Please help me in resolving the problem.
Your help will be highly appreciated.
Thanks in advance.
***Moderator Edit: Vidyaranjan| Updated Categories***
You should give the 2nd part of XML Stream rule as response in Service-SOAP rule.
XML StreamEnter either the Stream Name — second key part — of the appropriate XML Stream rule or a page name and stream name using the syntax PageName.StreamName. (The page must be on the clipboard when the service rule runs for rule resolution to find the rule.) If you specify the stream name only, the system uses the Page Class of this service rule (on the Service tab) as the first key part of the HTML rule.Note: To reference an XML Stream rule, the following conditions must be met:
MapFrom. If the generated XML Stream rule does not contain this key, resave it and specify the new XML Type Key.
