Pega 7.2.1 migrate script for PRPC62SP1 failing
Dear Upgrade community
Upgrading PRPC62SP1 on Oracle Proprietary information hidden on same database using out-of-place approach.
The migrate script is failing during SchemaGenerator.main(SchemaGenerator.java:1652), with Connection reset exception.
Have independently checked in SQL Developer that Deployment user, new RULES schema and existing PRPC62SP1 user can all connect with no problems.
Would like to check if anyone has seen a similar issue.
_callDDLUtilitySource:
[echo] Call DDL Generation Source XML Utility...
[echo] /explsauve/tomcat/PP1/media/115143_Pega721/scripts/lib/xercesImpl.jar;/explsauve/tomcat/PP1/media/115143_Pega721/scripts/lib/xml-apis.jar;/explsauve/tomcat/PP1/media/115143_Pega721/scripts/lib/resolver.jar;
[echo] archive_dir: /explsauve/tomcat/PP1/media/115143_Pega721/scripts/lib
[java] Exception in thread "main" java.lang.RuntimeException: Error during execution of source on platform oracledate using schemas PEGA, PEGA
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.main(SchemaGenerator.java:1652)
[java] Caused by: java.sql.SQLRecoverableException: Erreur d'E/S: Connection reset
[java] at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:467)
[java] at oracle.jdbc.driver.PhysicalConnection.<init>(PhysicalConnection.java:546)
[java] at oracle.jdbc.driver.T4CConnection.<init>(T4CConnection.java:236)
[java] at oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java:32)
[java] at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:521)
[java] at com.pega.pegarules.util.deploy.JDBCUtils$ClassLoaderDriverProxy.connect(JDBCUtils.java:56)
[java] at java.sql.DriverManager.getConnection(DriverManager.java:664)
[java] at java.sql.DriverManager.getConnection(DriverManager.java:208)
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.getDBConnection(SchemaGenerator.java:1321)
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.getConnectionFromArguments(SchemaGenerator.java:2257)
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.main(SchemaGenerator.java:1589)
[java] Caused by: java.net.SocketException: Connection reset
[java] at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:113)
[java] at java.net.SocketOutputStream.write(SocketOutputStream.java:153)
[java] at oracle.net.ns.DataPacket.send(DataPacket.java:210)
[java] at oracle.net.ns.NetOutputStream.flush(NetOutputStream.java:230)
[java] at oracle.net.ns.NetInputStream.getNextPacket(NetInputStream.java:312)
[java] at oracle.net.ns.NetInputStream.read(NetInputStream.java:260)
[java] at oracle.net.ns.NetInputStream.read(NetInputStream.java:185)
[java] at oracle.net.ns.NetInputStream.read(NetInputStream.java:102)
[java] at oracle.jdbc.driver.T4CSocketInputStreamWrapper.readNextPacket(T4CSocketInputStreamWrapper.java:124)
[java] at oracle.jdbc.driver.T4CSocketInputStreamWrapper.read(T4CSocketInputStreamWrapper.java:80)
[java] at oracle.jdbc.driver.T4CMAREngine.unmarshalUB1(T4CMAREngine.java:1137)
[java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:290)
[java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:192)
[java] at oracle.jdbc.driver.T4CTTIoauthenticate.doOSESSKEY(T4CTTIoauthenticate.java:404)
[java] at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:385)
[java] ... 10 more
BUILD FAILED
/explsauve/tomcat/PP1/media/115143_Pega721/scripts/migrateSystem.xml:507: The following error occurred while executing this line:
/explsauve/tomcat/PP1/media/115143_Pega721/scripts/setupDDL.xml:406: Java returned: 1
Total time: 3 minutes 54 seconds
Ant Process returned a non 0 value
