Capgemini
Last activity: 12 Jul 2017 12:32 EDT
Generate excel with multiple tab in PRPC 6.1 SP2
Hi ,
I followed the approach given in the article : https://pdn.pega.com/community/pega-product-support/question/creating-excel-report-multiple-tabs
It is working fine in 7.1.9 version. But while implementing it in PRPC 6.1 SP2 , a corrupt excel file is getting generated and when open that excel file getting the error :
Can anyone help ?
So it appears that the Activity response *itself* has been streamed to the client , rather than the Excel sheet.
Since the 'Excel' file which is opening basically contains the Activity 'Status: good' ; not sure why.
You need to post your Activity here so we can take a look.
Can you get to this link or not ? https://mesh.pega.com/docs/DOC-89784
(There is a worked example using the XML Stream Rules to generate Multi-tabbed Excel Sheets [in Office 2003 XML format there).
Can you re-post the error - the screenshot doesn't seem to have worked ?
Capgemini
PFB the error screen shot:
And if you can't get to the link: here's some PDFs of that (and two related posts) that give details of how to build multi-sheet Excel sheets from PRPC - using two methods - XML method and Apache POI.
The original post contains RAP files - which are not present in the PDFs; but the screenshots should be enough to rebuild - there are also some minor formatting issues in the PDFs - but you should be able to rescue it with a bit of copy/paste work.
Capgemini
Thanks for your help. Now it is working.
Cognizant
Just FYI,we can aechive this functionality by using below java code too.
try{
//String excelFileName = "/usr/pega/temp/PCS/pcs7devb_temp/StaticContent/global/ServiceExport/BKTestFile.xls";
//name of excel file
String excelFileName=tools.getParamValue("CCFFilePath");
int MNCDH=tools.findPage("MSGRNonCDH").getProperty("pxResults").size();
int MCDH=tools.findPage("MSGRCDH").getProperty("pxResults").size();
int NCDH51=tools.findPage("NONCDH51").getProperty("pxResults").size();
int CDH=tools.findPage("CDH51").getProperty("pxResults").size();
int EXP1=tools.findPage("EXCP1").getProperty("pxResults").size();
int EXP2=tools.findPage("EXCP2").getProperty("pxResults").size();
int SGX=tools.findPage("SGEX").getProperty("pxResults").size();
int PageIndex=0;
int ColIndex;
String ColumnValue="";
org.apache.poi.hssf.usermodel.HSSFWorkbook wb = new org.apache.poi.hssf.usermodel.HSSFWorkbook();
org.apache.poi.hssf.usermodel.HSSFFont font = wb.createFont();
font.setBoldweight(org.apache.poi.hssf.usermodel.HSSFFont.BOLDWEIGHT_BOLD);
org.apache.poi.hssf.usermodel.HSSFCellStyle styleBold = wb.createCellStyle();
org.apache.poi.hssf.usermodel.HSSFCellStyle styleWrap = wb.createCellStyle();
styleBold.setFont(font);
try{
int PageIndex=0;
int ColIndex;
for (int SheetNo=0;SheetNo < 7; SheetNo++ ) {
String sheetName="";
if (SheetNo==0) {sheetName = "MSGR-NON CDH";}
else if (SheetNo==1){sheetName = "MSGR-CDH";}
else if (SheetNo==2){sheetName = "51+ NON CDH";} //name of sheet
org.apache.poi.hssf.usermodel.HSSFSheet sheet = wb.createSheet(sheetName) ;
//iterating r number of rows
if (SheetNo==0)
//MSGR-NON CDH
for (int RowNo=0;RowNo < MNCDH+1; RowNo++ )
org.apache.poi.hssf.usermodel.HSSFRow row = sheet.createRow(RowNo);
if (RowNo>0)
PageIndex=RowNo;
ClipboardPage MSGRNCDHPage = tools.findPage("MSGRNonCDH").getProperty("pxResults").getPageValue(PageIndex);
for (int ColNo=0;ColNo < 13; ColNo++ )
org.apache.poi.hssf.usermodel.HSSFCell cell = row.createCell(ColNo);
if (ColNo==0){ColumnValue=MSGRNCDHPage.getString("CFProductID");}
else if (ColNo==1){ColumnValue=MSGRNCDHPage.getString("INDIVIDUALDEDUCTIBLE");}
else if (ColNo==2){ColumnValue=MSGRNCDHPage.getString("FAMILYDEDUCTIBLE");}
else if (ColNo==3){ColumnValue=MSGRNCDHPage.getString("NONMAINTGENERIC");}
else if (ColNo==4){ColumnValue=MSGRNCDHPage.getString("NONMAINTPREFERRED");}
else if (ColNo==5){ColumnValue=MSGRNCDHPage.getString("NONMAINTNONPREFERRED");}
else if (ColNo==6){ColumnValue=MSGRNCDHPage.getString("NONMAINTSELFINJSPECS");}
else if (ColNo==7){ColumnValue=MSGRNCDHPage.getString("NONMAINTMAXDAYSSUPPLY");}
else if (ColNo==8){ColumnValue=MSGRNCDHPage.getString("MAINTGENERIC");}
else if (ColNo==9){ColumnValue=MSGRNCDHPage.getString("MAINTPREFERRED");}
else if (ColNo==10){ColumnValue=MSGRNCDHPage.getString("MAINTNONPREFERRED");}
else if (ColNo==11){ColumnValue=MSGRNCDHPage.getString("MAINTSELFINJSPECS");}
else if (ColNo==12){ColumnValue=MSGRNCDHPage.getString("MAINTMAXDAYSSUPPLY");}
cell.setCellValue(ColumnValue);
else
if (ColNo==0){ColumnValue="RX PRODUCT ID";}
else if (ColNo==1){ColumnValue="IND DEDUCT";}
else if (ColNo==2){ColumnValue="FAM DEDUCT";}
else if (ColNo==3){ColumnValue="GENERIC";}
else if (ColNo==4){ColumnValue="PREFERRED";}
else if (ColNo==5){ColumnValue="NON PREFERRED";}
else if (ColNo==6){ColumnValue="SELF INJ - SPECIALTY";}
else if (ColNo==7){ColumnValue="DAYS SUPPLY";}
else if (ColNo==8){ColumnValue="MAINT GENERIC";}
else if (ColNo==9){ColumnValue="MAINT PREFERRED";}
else if (ColNo==10){ColumnValue="MAINT NON PREFERRED";}
else if (ColNo==11){ColumnValue="SELF INJ - SPECIALTY";}
else if (ColNo==12){ColumnValue="DAYS SUPPLY";}
cell.setCellStyle(styleBold);
sheet.autoSizeColumn(ColNo);
//SmallGrp Exchange
for (int RowNo=0;RowNo < SGX+1; RowNo++ )
if (RowNo>0)
PageIndex=RowNo;
ClipboardPage SGEXPage = tools.findPage("SGEX").getProperty("pxResults").getPageValue(PageIndex);
for (int ColNo=0;ColNo < 18; ColNo++ )
if (ColNo==0){ColumnValue=SGEXPage.getString("CFProductID");}
else if (ColNo==1){ColumnValue=SGEXPage.getString("INTEGRATEDOOP");}
else if (ColNo==2){ColumnValue=SGEXPage.getString("DEDACCUMMETHOD");}
else if (ColNo==3){ColumnValue=SGEXPage.getString("INDIVIDUALDEDUCTIBLE");}
else if (ColNo==4){ColumnValue=SGEXPage.getString("FAMILYDEDUCTIBLE");}
else if (ColNo==5){ColumnValue=SGEXPage.getString("INDIVIDUALOOP");}
else if (ColNo==6){ColumnValue=SGEXPage.getString("FAMILYOOP");}
else if (ColNo==7){ColumnValue=SGEXPage.getString("HBSELECTGENERIC");}
else if (ColNo==8){ColumnValue=SGEXPage.getString("NONMAINTGENERIC");}
else if (ColNo==9){ColumnValue=SGEXPage.getString("NONMAINTPREFERRED");}
else if (ColNo==10){ColumnValue=SGEXPage.getString("NONMAINTNONPREFERRED");}
else if (ColNo==11){ColumnValue=SGEXPage.getString("NONMAINTSELFINJSPECS");}
else if (ColNo==12){ColumnValue=SGEXPage.getString("NONMAINTMAXDAYSSUPPLY");}
else if (ColNo==13){ColumnValue=SGEXPage.getString("MAINTGENERIC");}
else if (ColNo==14){ColumnValue=SGEXPage.getString("MAINTPREFERRED");}
else if (ColNo==15){ColumnValue=SGEXPage.getString("MAINTNONPREFERRED");}
else if (ColNo==16){ColumnValue=SGEXPage.getString("MAINTSELFINJSPECS");}
else if (ColNo==17){ColumnValue=SGEXPage.getString("MAINTMAXDAYSSUPPLY");}
if (ColNo==1 || ColNo==2)
styleWrap.setWrapText(true);
cell.setCellStyle(styleWrap);
else
else if (ColNo==1){ColumnValue="INTEGRATED BENEFITS";}
else if (ColNo==2){ColumnValue="STACKED OR UNSTACKED";}
else if (ColNo==3){ColumnValue="IND DED";}
else if (ColNo==4){ColumnValue="FAM DED";}
else if (ColNo==5){ColumnValue="IND OOP";}
else if (ColNo==6){ColumnValue="FAM OOP";}
else if (ColNo==7){ColumnValue="HEALTHYBLUE SELECT GENERICS";}
else if (ColNo==8){ColumnValue="GENERICS";}
else if (ColNo==9){ColumnValue="PREFERRED BRAND";}
else if (ColNo==10){ColumnValue="NON PREFERRED BRAND";}
else if (ColNo==11){ColumnValue="SPECIALTY DRUGS";}
else if (ColNo==13){ColumnValue="MAINT GENERICS";}
else if (ColNo==14){ColumnValue="MAINT PREFERRED BRAND";}
else if (ColNo==15){ColumnValue="MAINT NON PREFERRED BRAND";}
else if (ColNo==16){ColumnValue="SPECIALTY DRUGS";}
else if (ColNo==17){ColumnValue="DAYS SUPPLY";}
java.io.FileOutputStream fileOut = new java.io.FileOutputStream(excelFileName);
java.util.Map xlZipEntryMap = null;
//write this workbook to an Outputstream.
wb.write(fileOut);
com.pegarules.generated.pega_appdefinition_excelintegration.DCOzipEntryMapToStream(xlZipEntryMap, fileOut);
pega_rules_default.downloadFile(excelFileName.toString(), tools, true);
//fileOut.flush();
//fileOut.close();
oLog.infoForced("Test CC file Generated "+excelFileName);
}catch(Exception e){oLog.error("Error in Generation CC file");}
