JPMC
Last activity: 14 Nov 2016 9:29 EST
warning when do do saveas of property in higher ruleset
I am using PRPC 7.2.1 When we have a property in a locked lower Ruleset and we want to make some changes in that property say add edit validate rule or amth else, and we do a saveas of that property in higher ruleset, PRPC gives a warning popup saying
"A property of this name already exists for the chosen applies to class. It is either inherited from a parent class or in a different ruleset than the one chosen. Duplicate property definitions can negatively impact system performance.
Do you want to create anyway?"
Why do this come and is there a better way to update that property in locked RS than overwritting it in higher RS?
***Updated by Moderator: Vidyaranjan| Included Categories***
CGI Netherlands
Hi Ashish,
Duplicate properties restrict the system's ability to optimize rules assembly.
Pega recommends us to rename the properties to avoid this problem but its not a correct solution. Basically you can save as a property if really needed and ignore the warning.
More details
https://community.pega.com/sites/default/files/help_v63sp1/Default.htm
JPMC
ah, can't PRPC handle the rule resolution for properties as well as it does for other rules... as during devlopemnt its common to get changes in properties... and renaming property would lead to unnecessary properties and also need update in all places where the property is used... which can be a big task..
JPMC
Can any SME help me on this?
Is it not possible to change the property in the lower ruleset, by unlocking it? If there is a reason to keep the old one, then I would seriously consider that the same reason to create a new property name for clarity and to avoid subtle bugs.
Pegasystems
I would think the better way is to never unlock the RS in your "higher" environments such as qa and prod, but instead to unlock the RS in your "lower" environment such as dev, do a checkout of your property rule, make the desired change, and do a checkin of the property. Then, after testing, re-lock the RS and use a rule-admin-product to import it to your higher env.
/Eric
JPMC
Actually it is not permitted to unlock the ruleset which are locked, either in dev or in higher env... so the question is why pega do it different just for properties whereas for all other rules it takes care automatcically in rule resolution...
CGI Netherlands
Hi Ashish,
This is just a guess. Since properties are referenced almost all the rules and PEGA keeps looking on each property for Database Column mapping for each property created and the relation between them is also monitored by PEGA rules. This makes it complex for rule resolution to rule out the invalid Properties. This is the reason PEGA provides this Warning only for properties. Again it’s just a warning so you can save as the property to do the desired changes.
JPMC
Hi Team,
Can some SME from Pega answer my question as why is this a special case for properties and not same as other rules?
Hi
They key activity involved in displaying / forming the warning is onBeforeDisplay. It is having a copy in almost all the rule specific classes ( e.g Rule-Obj-Property, Rule-Obj-HTML etc )
Upon saving as any rule on higher ruleset version , PRPC first calls the rule class specific activity and then calls the @baseclass one.
I can see for property , the activity OnBeforeDisplay ( under Rule-Obj-Property ) has some additional steps which is perhaps responsible for showing the warning. However the same activity under Rule-Obj-HTML does not have all those steps and thats the reason may be the warnings are not displayed.
This is my thought. But I am not sure the motive behind doing such design . Anil Vanaparthy any thoughts ?
JPMC
Yes, my question is to understand why is it different for properties. I know there is extra validation for properties and thus showing warning... but why?
Areteans Technologies
Properties are used to hold values considered as column in table or BLOB. Pega advices no major changes to the existing column/property in general, and so the warning. To eliminate warning you can choose Extension as Status in the Rule availability area.
This is very interesting question. Sometime we might just want to update the label for the property , So we need to save it in higher version. We are not supposed to unlock locked version in dev also.
-Saikat
You can unlock the same version and update the label (short description) and move the same to higher environments.
No, Unlocking a ruleset is never a good option for any change.
JPMC
Agree, unlocking ruleset is never a solution for real time applications, its against the policies.
I have not received any convincing answers for my question yet, plz help.
