Cognizant
Renaming Case Type
I renamed a Case Type. But still in Create Menu Old name is appearing. can you please suggest how to fix this.
PSC
Did you try changing the case type name in Cases And Data tab of application rule?
Cognizant
Yes. Still the Create Menu shows old names.
Capgemini
SE
Did you try to modifiy the description of start flow (pyStartCase)?
PSC
I have the same issue...
I've changed the name as suggested:
- in the case type name in Cases And Data tab of application rule
- the description of start flow (pyStartCase)
But still the Create Menu shows old names.
Thanks for helping.
What Pega version are you using?
Incessant Technologies
Try changing the case's class label.
Accenture India
this helped. Thanks.
Hi MadhanR7,
Which Pega release your application is on?
I checked my Pega 7.1.9 and Pega 7.2.1 systems.
On Pega 7.1.9, "Rename" menu is available for use to rename the case type. See below PDN help article.
https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm
Did you follow the above to rename the case type?
On Pega 7.2.1, this menu is no longer available.
I captured two screen shots and attached here.
Susan
PSC
It's working now... I'm on Pega 7.1.9
After the two steps bellow, I changed the availability of the case to Not Available, and back to Available.
Thank you for your assistance.
MacQuarie Bank Ltd
My application is currently in production Pega 7.1.9. Suddenly, there is a requirement to rename a case type. So by only running the rename wizard it will work ??
Will it impact the existing cases of that case type in production ??
what about other environment like QA, Sit, Uat, Prod. Do we need to run wizard in every environment or need to move any specific rule type or ruleset version from the product (Rule-Admin-Product) ???
