Nationale Nederlanden
Last activity: 23 Aug 2016 13:54 EDT
DB connection error
We are running Pega 6.2 SP1 on a Websphere environment with a DB2 database. When we have infra changes, the Websphere server is stopped, the the database server stoppd. After the infra change the DB server is started and then Websphere is started. Then Pega is working fine. But when the DB server is started later then the Websphere server we got a Database connection error, even when the DB server is up and running. Is there a way that Pega does a automatic reconnect to the database server?
***Updated by Moderator: Marissa. Removed user added helpme and Ask the Expert Group tags. Apologies for confusion, shouldn't have been an end-user option***
