Capgemini
Error : "Unable to open assignee's Data-Admin-Operator-ID record [email protected]".
Hi I am new to Pega, I have created Cases, Stages and Process steps for an application. while run through the entire process to verify the case behaviour, I have encountered the Error : "Unable to open assignee's Data-Admin-Operator-ID record [email protected]".
All the process steps which are created as Approve/Reject are throwing an error instead of giving a pop-up for approval.
Please help me to get me out of this issue.
Thank you
Srikanth K
***Updated by Moderator: Vidyaranjan. Removed user added #helpme and Ask the Expert tags. Apologies for confusion, shouldn't have been an end-user option***
***Updated by moderator: Lochan to move from PSC to Pega Academy***
AIG
This is a bug in the instance.
Do the below to fix this issue -
- Open the Work Group Instance "default@TGB. (Navigation: Designer Studio - Records - Organization - Work Group)
- Check the value for "Manager" field. It should be [email protected] and error symbol may be shown against it.
- Change the "Manager" value to "admin@TGB".
You may find this article helpful: https://community.pega.com/support/support-articles/workflow-fails-error-step-assignment63
FR
I think your flow is trying to root a task to a WorkBasket but the rooting parameter is [email protected] and this is a user having a WorkList, not a WorkBasket.
capgemini
i dont get u. plz explain it clearly
Hello!
The user communicated to the the PSC moderators (via a private message) that this issue was observed in the exercise system while trying out an example. The issue was not replicated on the personal edition system.
The user also communicated that he would post the resolution after reviewing the exercise system again!
Lochan | Community Moderator | Pegasystems Inc.
Infosys
BE
At which stage it is happening. Expalin it elaborately please.
Infosys
BE
AIG
Dell
how to login to Workgroup instance, i tried the generic password and it wont let me in.
Taran
SG
You do not login to a workgroup. You only login as a member of a workgroup. If you are using a Pega Academy exercise system, the default password is rules.
Florida Blue
what is the navigation on Pega Express, the Pega Academy exercise system.
SG
I'm not sure I understand your question. What are you attempting to achieve? Navigating to Pega Express?
Sentry Data System
Thank You Harish I'm was able to resolve this bug with you above resolution..
