Infosys
Last activity: 21 Jul 2017 9:55 EDT
Unable to view rule search results
I am able to view the search results of rules on the PEGA Developer Portal intermittently. Any reason why this might be happening and resolutions? I am using PRPC 6.3
***Updated by moderator: Lochan to close post***
Pegasystems
Please check the search landing page (Pega Icon -> System -> Settings -> Search) to see if the search indices are up to date and all the details on that page are correct.
If there are multiple nodes in your cluster please check the logs of the current node and the search node to see if any errors or exceptions are there.
Infosys
When i check the SMA for the search node. On clicking the search node i get the error
Failed to invoke an operation
java.lang.Exception: Failed to invoke MBean
operation.
Name:
com.pega.PegaRULES:cell=ZB19,id="fb733093bd8d2374e3066c1ccc018349",name=com.pega.pegarules.management.internal.SystemManagement,node=wsfpp1lpqza173,process=wsfpp1lpqza173starpuatServer,type=enterprise
opName: SystemStatus
Failed to invoke MBean operation
java.lang.NoClassDefFoundError:
com/pega/pegarules/priv/management/ManagementAPIHelper
Pegasystems
Can you open the URL to the search node to check if you can login to that node?
Infosys
Yes, i am able to login to that node.
Pegasystems
Great. Would you be able to check the log files on that node to see if there are any exceptions?
Infosys
Against the agent "SystemWorkIndexer" under system >> settings , i get the following exception :
Exception at 20150329T184401.829 GMT:
com.pega.pegarules.pub.PRRuntimeException: caught DatabaseException while trying to open conclusion Property!PXRDBERROR: Database-General Problem encountered when getting connection for database pegarules -4499 08001 [jcc][t4][2043][11550][3.64.133] Exception java.net.ConnectException: Error opening socket to server adc1db2d.ipc.us.aexp.com/ Proprietary information hidden on port 7,320 with message: Connection refused. ERRORCODE=-4499, SQLSTATE=08001CWWRA0010E: SQL State = 08001, Error Code = -4,499
Pegasystems
Looks like it is unable to connect to the DB2 database on the given server host name and port. Did you try doing this outside of PRPC but from the same machine?
