Create Users in PEGA from backend DB table
We do have requirement to create users in PEGA. Below are the questions we are seeking answer to:
1) If we create an user entry in the PR_OPERATORS table from backend, will that create the operator ? Do we need add / update any other table ?
2) Can we disable / enable the Operator ? If so, what attribute should be updated ?
3) For deletion of the operator, can we simply remove the record from PR_OPERATORS table ? Is there any dependency on other table ?
4) Which column in the table PR_OPERATORS signifies the Operator Type ?
