How to create cases from the backend
I have a requirement where I need to Initiate Cases and case stages from the backend.
Hi Jeet,
You can write an activity that calls the createWorkPage activity to set up the data, then AddWork to create the work object, and commitwitherrorhandling to commit the work object.
Carissa
Can we push this work object created by createWorkPage activity into a case ?
So that case processing starts
Hi Rasaiya,
When I create a new case work type using the Case Designer, a pyStartCase flow is automatically generated for me. This flow contains a utility step pzInitializeStage. When you use createworkpage to set up your work object data you could specify the pyStartCase flow so the stages are initialized.
Cool, Will try these, thanks for the help âº
this is commonly done by service-soap or listeners (e.g., MDB). PegaAPI is another to initiate case creation through REST API. Check the online help.
RULE-OBJ-ACTIVITY WORK- SVCADDWORKOBJECT be of help?
