Pegasystems
Last activity: 17 Aug 2015 14:54 EDT
6.3sp1 can't create product file from rule-admin-product
I'm on 6.3sp1 attempting to use the "Create Product File" button on the rule-admin-product form, which I've used hundreds of times before, and suddenly today I can not create my zip and I'm wondering if any of you know how I might repair this issue. Here's the button I'm trying to use:
I get the standard popup asking me my zip file name should be, and after I specify that, it just sits there.
Below are a sample of the console logs I am seeing. Notice that they occur every 2 seconds.
I assume this is all happening in a batch process and hence merely tracing the button doesn't show much. Maybe there's a way to at least get a stack trace to be shown on each warning ? Is that a prconfig setting ?
Thanks. /Eric
2015-08-17 10:48:36,859 [ PegaRULES-Batch-2] [ STANDARD] [pegasupport:01.01.01] ( internal.util.CollectorImpl) WARN pegasupport - Unable to obtain table
information for PegaCPMHC-Interface-Notes: Database-General Problem encountered when getting connection for database sample 12514 66000 Listener refused
the connection with the following error:
ORA-12514, TNS:listener does not currently know of service requested in connect descriptor
Thanks. /Eric
2015-08-17 10:48:40,341 [ PegaRULES-Batch-2] [ STANDARD] [pegasupport:01.01.01] ( internal.util.CollectorImpl) WARN pegasupport - Unable to obtain table
information for PegaApp-Interface-BusinessUnit: Database-General Problem encountered when getting connection for database sample 12514 66000 Listener
refused the connection with the following error:
2015-08-17 10:48:42,628 [ PegaRULES-Batch-2] [ STANDARD] [pegasupport:01.01.01] ( internal.util.CollectorImpl) WARN pegasupport - Unable to obtain table
information for PegaApp-Interface-Notes: Database-General Problem encountered when getting connection for database sample 12514 66000 Listener refused
2015-08-17 10:48:44,922 [ PegaRULES-Batch-2] [ STANDARD] [pegasupport:01.01.01] ( internal.util.CollectorImpl) WARN pegasupport - Unable to obtain table
information for PegaApp-Interface-LocationCategories: Database-General Problem encountered when getting connection for database sample 12514 66000 Listener
2015-08-17 10:48:47,221 [ PegaRULES-Batch-2] [ STANDARD] [pegasupport:01.01.01] ( internal.util.CollectorImpl) WARN pegasupport - Unable to obtain table
information for PegaApp-Interface-Roles: Database-General Problem encountered when getting connection for database sample 12514 66000 Listener refused
